It’s still a little confusing trying to understand what you’re really after, however, I think your issue is with ReplaceItemAtIndex (assuming it’s the OOTB node). That node replaces a singular index from a singular list. Meaning it won’t replace multiple items from the same list at the same time. You would need a custom node (archi-lab has one) or python to get what I believe you’re after.
Apologies for the confusion, I’ve updated the original post to show codeblock of what I am trying to achieve. Hopefully that makes more sense.
I have tried the archilab & clockwork nodes. Still couldn’t get what I wanted, plus they both gave different results.
I guess I will hope someone has a python method or direction on level/lacing for custom node.
If not, I’ll have to think of another way (avoid using the replaceitematindex node) to compile the list.
A more simple example might be helpful. It’s hard to follow when we can’t see the entire list at once. A simpler example is also a good way to prove the process works before introducing additional items or list structures.
Another thing, I have situations where the sublists are replaced in the middle of the “parent” layer only.
Can your python script be modified to handle that? See below: replaceitemindex_test_middle.dyn (38.6 KB)
