I have a list that has some null value interspersed in it. I would like to replace nulls with the previous value actual value. Note that there can be multiple nulls in a row.
thanks much
thanks much
@Jpeele_JDB See if this helps:
toNestList = lambda x: x if any(isinstance(i, list) for i in x) else [x]
OUT = [[x if x else i[j-1] for j,x in enumerate(i)] for i in toNestList(IN[0])]
This would not work as intended if you have 2 nulls back to back or if index 0 is a null.
@Jpeele_JDB And this should take care of the back to back nulls:
OUT = []
for i in toNestList(IN[0]):
out = []
for x in i:
if x:
out.append(x)
out.append(out[-1])
OUT.append(out)
This would not work as intended if index 0 is a null.
@GavinNicholls That’s the 1st thing I tried but missed the @L2 in haste and assumed “if” didn’t work as usual! Thanks for pointing it out.
If very rarely works (as desired), no worries - I quite like the Python approach as well!
Ah yes sorry i misunderstood the intent or your script (I overlooked the shift). The Python approach is best here, you’re right.
