I am now trying to write a Dynamo graph to repath broken PDF links when our main project folder gets renamed. I have succesfully figured it out for Revit and CAD links by reading the file path and changing the old folder name to the new name and repathing it using the Orchid node. However, I am unable to get any information on PDF links…
Hi
you can use the Revit API with this method
Example
import sys
import System
clr.AddReference("System.Numerics")
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
old_directory_path = IN[0]
new_directory_path = IN[1]
out = []
all_imagesType = FilteredElementCollector(doc).OfClass(DB.ImageType)
for imgType in all_imagesType:
current_path = imgType.Path
print(current_path)
file_name = System.IO.Path.GetFileName(current_path)
if old_directory_path in current_path:
new_file_path = System.IO.Path.Join(new_directory_path, file_name)
if System.IO.File.Exists(new_file_path):
newImg_opt = ImageTypeOptions(new_file_path, False, ImageTypeSource.Link)
imgType.ReloadFrom(newImg_opt)
out.append(f"Success repath : {new_file_path}")
out.append(f"Failed repath : {new_file_path}")
OUT = out
