because this package not in the shared packages.
Bold-To_From Room.dyf (10.2 KB)
does it work ?
does it work ?
Hi Memet_Akcan , no at all it’s not working
Hi @Mostafa_El_Ayoubi
Thank you so much man it’s working perfectly, but there is some little issue if you can check the attached image.
And another different question you don’t mind please (if the room Name (L1-032) and I want to add only this part(032) to the door number can I or not)??
@Mostafa_El_Ayoubi
thanks for a reply, yes I did it but still not working, I changed code block TO (0…List.Count(a<1>)+1;)
and it’s working except 2 doors I don’t know why!!!
For the second part see the image below, (this is what I want ):
I’m numbering the room without any suffix ,then I get this parameter to renumber the door with the same number of room, and for the room tag i created another shared parameter have the same number of room with the suffix (L1-) (using SetParameterByName node)
I will attach the full dynamo if you want to check it
ROOMCURVINGNUMBERTARIQ.dyn (23.2 KB)
Hello guys,
I have small question
regarding room number I need it start from 001 …020…120
how I can show it like this start with double zero if I have one number , or one zero if I have 2 number …
Hi @de_tarek2
Please post your question by creating new topic. This is off topic. Thanks ![]()
@Kulkul
Okay
