Renumbering Project Browser Sheets
Hi all,
I have been tasked re-order sheets and it’s very time consuming, for example;
Sheet 7200, 7201, 7202…all the way to sheet 7240. If delete sheet 7205 (for example), I need to go and renumber the next 35 sheets to have -1 number. Is there a way to generate the new sheet numbers in order using Dynamo?
Thanks!
Hello @c.mccracken and welcome to the forum…Bimorph had some nodes for that…here is if you wanna use ootb nodes…good luck.
Thanks for your quick reply! Being a Dynamo rookie, I cant seem to find the passthrough node? Cheers
Thats one is from Clockwork
