Hi dynamo’s expert,
I just start to learn dynamos and I need help.I need to rename all my view’s filter.I’m wondering if it’s possible with dynamos ? here what i did until now.
thank’s for help
what does the error say
(look for it in the yellow marker on the top of the node)
I see you have changed the name of the parameter from “Nom” to “Name”
It’s said there’s no parameter found By that name …
For the name i’m using french version,I changed the ''nom"" to ''name" because i tried the English version to try if it works.
I want to change filter name .I think that the name parameter is name.
can you try this:
use element.parameters to check the Name -or Nom-
use the output from filter by booleanmask (IN)
This is what you get:
I dont think you are feeding in Filters here
Yes I am.
I was just testing the problem while you wrote the post.
Indeed , I doestn’t work for me ,
I think that I’am gonna change 214 name’s filter manually…
I found that the node Element.SetParameterByName has to be replaced by Element.SetName
YEAAAAAAH, it’s work thank you so much you make me very Happy
Well done @m.rijsmus!
@meniai.toufik1: please mark his solution as the solution for this topic and drop some likes here and there
