First I want to take all the views and filter them by ‘string contains’. When I watch the output after the ‘List.FilterByBoolMask’ node, I read that the desired views for renaming are all that remain. But after I connect the final node ‘Element.SetParameterByName’ and press ‘run’. It does not rename the corresponding views. Im I overlooking a step? Any input is very much appreciated.
You are feeding the ‘Element.SetParameter’ Values into the Boolean Mask, rather than the ‘All Elements of Category’ Node so your Watch node shows you the values, it should instead be showing you the objects.
I also tend to need a ‘list clean’ and find it useful to filter out view templates using the View.IsViewTemplate node with a boolean filter.
No worries, I would be grateful if you could mark my reply as solved.
I guess I need to do an update! You’ll find a core node Clean and an Archi-lab version, but the DanEdu version has always given me the best results, there does appear to be a version listed here…
