Rename walltype, how?
Hello Dynos,
It is late, #homeoffice
How can I rename a walltype with dynamo? I want just add “H_” to all my walltypes as prefix,how?
I think i stuck in this string to element-topic, it works as a string very well! but how the hell i can edit it to the typename.
KR
Andreas
What is the code contained within the Element.SetName node?
RenameFamilyType.dyn (12.2 KB)
You are naming the actual walls, you should name its type, use elementtype node after elements
That was it thank you!
