Schedule View Name to Views
Good Day, I’ve been trying to hide a specific column field (“Number”) on my room schedule. This should be applied to all room schedule. What I’m trying to do is to convert all ScheduleViewName into views so that it would work on the script. Please help, Thank you!
Can you show the source code of the Hide Column node?
Hi here it is
clr.AddReference('RevitAPI')
from Revit.Elements import *
clr.ImportExtensions(Revit.GeometryReferences)
uiapp=DocumentManager.Instance.CurrentUIApplication
app = uiapp.Application
view = doc.ActiveView
def U(elem):
	a = UnwrapElement(elem)
	return a
schedule = UnwrapElement(IN[0])
colName = IN[1]
definit = schedule.Definition
countParameters = definit.GetFieldCount()
# Parameter names
names = []
for i in range(countParameters):
	Parname = definit.GetField(i).ColumnHeading # Parameter Column name
	if Parname == colName:
		index = i
field = schedule.Definition.GetField(index) # schedule field
field.IsHidden = IN[2] # 1 = Hide, 0 = Show
OUT = schedule
Hi @kdelacruz11221004 , let’s try this:
def U(elem):
    if isinstance(elem, list):
        return [UnwrapElement(e) for e in elem]
        return UnwrapElement(elem)
schedules = U(IN[0])
colName = IN[1]
hide = IN[2]
results = []
for schedule in schedules:
    if isinstance(schedule, Autodesk.Revit.DB.ViewSchedule):
        # Parameter names
        names = []
        index = None
                index = i
                break
        if index is not None:
            field.IsHidden = hide  # 1 = Hide, 0 = Show
            results.append(schedule)
            results.append(None)
OUT = results
In your previous code, you forgot to pass each schedule into a loop so it didn’t work.
Hi @Luffy11, You are amazing thank you so much for this now it works!
I do have 1 question tho, What if I want a multiple number of fields what should I edit in the script?
@kdelacruz11221004 just a little modification with loop as shown in the image and you can get the expected result.
Here’s the modified code:
def U(elem):
        return [UnwrapElement(elem)]
colName = IN[1]
hide = IN[2]
results = []
        # Parameter names
        index = None
            for name in colName:
                if Parname == name:
                    index = i
OUT = results
And put the IN[1] in the def U like this so that it can work for one or more columns.
Hi @Luffy11 Now it works, thank you so much! you are a great of help!
@kdelacruz11221004 , you’re welcome. I’m glad to help.
