Copy Property set definition
Hi all, is it possible to copy property set definition with new name and same definitions/attributes ? Is python necessary?
Hi all, now I can copy Property set definition. I used Python and I was inspired by @Paolo_Emilio_Serra1 pset_utils modules.
I don’t understand how to apply property set definition to “Solid3d” objects. I am in “learning by doing” process. Is here anyone who can help? I don’t understand how StringCollection() and SetAppliesToFilter() method works.
Here is code as it is now in my work in progress.
def copy_ps_definitions(propertySetDefinitionName):
    """Creates a copy of property set definition
    :param propertySetDefinitionName: The property set name to get property set definition.
    :returns:
    global adoc
    with adoc.LockDocument():
        with adoc.Database as db:
            psdef = None
            psdefid = None
            newps = False
            newpsdef = None
            newpsdefid = None
            mypsdef = None
            mypsdefid = None
                dpsd = DictionaryPropertySetDefinitions(db)
                psdef = PropertySetDefinition()
                psdefid = psdef.Id
                dpsd.AddNewRecord("name", psdef)
                newps = True
                psdefid = dpsd.GetAt("name")
                psdef = t.GetObject(psdefid, OpenMode.ForWrite)
                definitions = psdef.Definitions
                mypsdefid = dpsd.GetAt(propertySetDefinitionName)
                mypsdef = t.GetObject(mypsdefid, OpenMode.ForWrite)
                mydefinitions = mypsdef.Definitions
                for pd in mydefinitions:
                    definitions.Add(pd)
                #aplTo = psdef.AppliesToFilter.Contains.__doc__
                #sc = StringCollection()
                #scnew = sc.Add("Solid3d")
                #psdef.SetAppliesToFilter(scnew, False)
                #newpsdef = PropertySetDefinition()
                #newpsdefid = newpsdef.Id
                #dpsd.AddNewRecord("name", newpsdef)
                #newpsdef = t.GetObject(newpsdefid, OpenMode.ForWrite)
                #newpsdef.Definitions = definitions
                t.AddNewlyCreatedDBObject(psdef, True)
                t.Commit()
    return mydefinitions, definitions
Here is what was missing:
psdef.AppliesToAll = False
sc.AddRange(Array[str](["AcDb3dSolid"]))
psdef.SetAppliesToFilter(sc, False)
