Rename block
is there a possibility to rename BLOCK by dynamo ?
thanks for your help
The Camber library contains Block.SetName:
Tanks you very much
Thanks @Anton_Huizinga
I have Questions For example, I have 10 block same name and I want to rename them in a sequence, which node need to add for this code?
You can’t save the same Block with 10 different names.
