Hi All,
First timer here so i hope i explain what i require help with here.
We get sent from the architects house files that show everything from Walls roofs and radiators to fire alarms.
I’ve got a graph set up to remove all views, sheets & schedules which works fine. And a graph to remove all model elements which also works as it should. However i would like to keep some walls that are below ground and on a separate work-set labelled “substructure”. (The rest of the walls are on work-set “core”) So i’m struggled to filter out the substructure walls from being removed. I’ve attached an Image of what i currently get using my script (With missing walls) And the other is what i’d like to achieve (showing internal walls & End wall)
Also there is a screen shot of the basic layout of the graph. (As a new user it wont let me upload files)
Any advice would be greatly appreciated.
Kind Regards,
Lee
