Good evening. I am a beginner in Dynamo and my AIM Is ti obtain the Wall orientation in my model. As you can see from the list ‘All elements of category’ i have both Wall and FaceWall, these last items are the ones that puts the script in error. Is It possibile to filter the list of elements mantaining only ‘Wall’ instances and not ‘FaceWall’? Thanks in Advance
Prior to posting it is recommended to search the forum first.
Hi @umberto95,
Welcome to the Dynamo Forum.
Interesting question.
You have to use Python to filter the FaceWalls :
clr.AddReference('RevitAPI')
walls = UnwrapElement(IN[0])
result=[]
for wall in walls:
if not isinstance(wall,Autodesk.Revit.DB.FaceWall):
result.append(wall)
OUT = result
thank you for your fast reply. I’m a building engineer and my programming curriculum is almost zero. i tried to type the text in a code block but it says that i don’t have an EOF, also in the code block i don’t see the numbers in column as your screenshot; how should i act?
Thank you again
You probably forgot the ; or the " at the beginning and the end of the code block.
The numbers in column in the code block are only present in Dynamo 2.6 in Revit 2021.
Copy and paste would have saved you from this error.
It’s FaceWall and not Facewall.
I can not thank you enough for your help. Many thanks.
