Looking for tips on what nodes to use for moving a placed legend on a sheet. Can a legend be moved on a sheet with the use of dynamo? If not, what node(s) can be used to remove the legend from a sheet (not deleted from the project) to place by coordinates again?
Thank you for your reply. That would have been a solution, but the legend is placed on multiple sheets at different locations. Looking for an answer doing this through the use of dynamo.
Thank you. In this thread they talk a lot about placing legends on sheets by locations, but from what I have experienced, if a legend is placed on a sheet it will not update its location when the script is run with a revised location; only sheets without the specified legend will update to the new coordinates, but correct me if this is wrong. Then please advice me to what script (or what in the script); there are several mentioned in this thread, would also relocated placed legends.
