Remove Legends & Schedules From Sheets
I am trying to find a way to remove Legends and Schedules from a list of sheets in Revit. I can easily select the items that I want to remove from the sheet; however I can not find a way to just remove them, not delete them from Revit as the legends / schedules are being used on other sheets. I tried using the Element.delete from Archilab but this deletes the elements from the model, not just from the sheets.
Hi, have you found a solution to this? Thanks
@EditaV This should help
