Reload linked files, how?
2019-02-15_11h57_49
I just want to reload my links. with this script! Where is the solution?
Can i do here a “for” loop?
Right now i have no errors… but no effect! :slight_smile:
I am glad about any help
KR
Andreas
Hi @Draxl_Andreas,
Your script is to repath the links.
If you want to reload them you can do like this :
clr.AddReference('RevitAPI')
linkInstances = FilteredElementCollector(doc).OfClass(Autodesk.Revit.DB.RevitLinkInstance)
for link in linkInstances:
	linkType = doc.GetElement(link.GetTypeId())
	linkType.Reload()
OUT=linkInstances
… I tried it pidirectional - i just changed “Reload” to “Unload” but it didn`t work
For unloading the links, need i a different script?
KR
Andreas
Replace
linkType.Reload()
with :
linkType.Unload(None)
You maybe need a TransactionManager.Instance.ForceCloseTransaction()
if you reload and then unload.
