How To Reload All Revit Links
I try to Load Revit Links in model at once instead of reload them individually ,
and here-under my trial but not working
Any Ideas ???
– The Python Code :slight_smile:
import sys
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
import os
import ntpath
clr.AddReference(“RevitAPI”)
rlTypes =
fPaths =
names =
rvtLinkTypes = FilteredElementCollector(doc).OfClass(RevitLinkType)
if rvtLinkTypes:
for rlt in rvtLinkTypes:
rlTypes.append(rlt)
efr = rlt.GetExternalFileReference()
fPath = ModelPathUtils.ConvertModelPathToUserVisiblePath(efr.GetPath())
fPaths.append(fPath)
names.append(ntpath.basename(fPath))
OUT = rlTypes, fPaths, names
what are the errors that you are getting?
Also, please post any code using the Preformatted Text option </>.
Have you tried the Reload() method? :slight_smile:
http://www.revitapidocs.com/2018.1/86830eb9-5ddb-c342-fddd-6963e5c03564.htm
There are several nodes to reload all links or only selected links.
I Try it but unfortunately it doesn’t work
Ok I will thanks a lot
Hey @abdallahzakaria,
This is how you could do it:
clr.AddReference('RevitAPI')
rvtLinkTypes = FilteredElementCollector(doc).OfClass(RevitLinkType).ToElements()
bool = IN[0]
reloaded = []
if bool == True:
		reloaded.append(rlt.Reload())
	OUT = reloaded
	OUT = 'Set bool to True'
Use the Boolean toggle to ‘reset’ the python node if you need to rerun the graph multiple times without closing the session.
But as @Alban_de_Chasteigner, if you dont mind using costum packages, you might aswell do that. They are probably also more reliable then my snippet :slight_smile:
Good luck.
Thanks A lot dear I appreciate your reply
Thanks A lot Alban_de_Chasteigner
It works like a charm
