Reload linked models
Hello All,
I receive models which have links located on BIM360 storage. I place the linked files to the same folder with the host file. Now I need to reload links from that folder. I created a script for that, but it doesn’t work. Please advise.
import os.path
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.Analysis import *
app = uiapp.Application
links= UnwrapElement(IN[0])
#names= UnwrapElement(IN[1])
folder = BasicFileInfo.Extract(doc.PathName).CentralPath
folder = os.path.dirname(folder)
config = WorksetConfiguration(WorksetConfigurationOption.OpenLastViewed)
listOut = []
listOut.append("CENTRAL FILE LOCATION: " + folder)
i = 0 # index
for t in links:
#	name = names[i]
	name = t.GetParameters("Type Name")[0].AsString()
	i = i + 1
	n = name.find('.rvt')
	if n>1:
		name=name[0:n+4]
		name=name.replace("_detached","")
		if os.path.isfile(folder + "\\" + name) :
#			fp=name
			fp=folder + "\\" + name
			fpm=ModelPathUtils.ConvertUserVisiblePathToModelPath(fp)
# remove BIM360 path
			try:
				t.LoadFrom(fpm, config)
				listOut.append("LOADED: " + name)
			except:
				listOut.append("Link Fail: " + fp)
# Set path to Relative
			try:
				t.PathType = PathType.Relative
			except:
				name=name
OUT= listOut
Thank you.
