Reference line from Revit
Hi, I’m quite new in Dynamo.
I need to reference 5 specific curves from revit model.
which nodes should I use?
thanks in advance
Carlos
Select Model Elements.
Hi Konrad,
thanks.
Ok got it, the selection only works from windows selection,
I can’t pick one by one curve till I have the curves I need?
this is how its work?
best
C,
Yeah, box selection only.
You could select the lines you need then use the “Isolate Elements” command inside of Revit then window the lines you need.
