how can retrieve the duct shape. I found the duct shape class but don’t know how to use it.
Hi @shibujoseukken,
Can you show us your graph?
You can get shapes from Connectors, so connector manager etc.
i was trying to do this by python. but I got errors.
my code is here
Version:0.9 StartHTML:00000097 EndHTML:00003851 StartFragment:00000199 EndFragment:00003813 import clr
Import DocumentManager
Import RevitAPI
clr.AddReference("RevitAPI")
#from Autodesk.Revit.DB import *
from Autodesk.Revit.DB import Mechanical
from Autodesk.Revit.DB.Mechanical import DuctInsulation
from Autodesk.Revit.DB.Mechanical import DuctShape
from Autodesk.Revit.DB.Mechanical import DuctSettings
from Autodesk.Revit.DB import Connector
app = uiapp.Application
el = UnwrapElement (IN[0])
mepsystemList =
conManager =
cType =
shList =
co1List =
for i in el:
id = i.MEPSystem.Name
mepsystemList.append(id)
for cn in el:
con = cn.ConnectorManager
conManager.append(con)
for c in conManager:
co = c.Connectors
cType.append(co)
for sh in cType:
shape = sh.Shape
shList.append(shape)
#OUT = mepsystemList,cType,dir(cType[0]),dir(el[0])
OUT = cType
Looks like you’re trying to get the property from a list, ConnectorSet. You need to iterate through each Connector in the ConnectorSet.
