Get Rectangular, Oval and Round Size from Duct Settings
Hi all, it’s possible to collect Rectangular, Oval and Round Size from Duct Settings from the active document with the three colums “Size”, “Used in Size List” and “Used in Sizing” ?
Actually I can only collect DuctSettings and GetDuctSizeSettings
Thanks in advance
Cheers
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.Mechanical import *
from Autodesk.Revit.DB.Plumbing import *
from Autodesk.Revit.UI import TaskDialog
fec_DuctSettings = FilteredElementCollector(doc).OfClass(DuctSettings).ToElements()
GetDuctSizeSettings=DuctSizeSettings.GetDuctSizeSettings(doc)
OUT=fec_DuctSettings,[GetDuctSizeSettings]
Hi @paris
Is this what you want?
DuctSettings
Hi @Kulkul thank you for your answer, great! it’s exaclty what I’m looking for,
can you explain a bit more what methods/property are you used?
Cheers
Refer below for brief explanation:
https://thebuildingcoder.typepad.com/blog/2013/10/programmatic-access-to-duct-sizes.html
Thanks @Kulkul how translate “foreach( KeyValuePair<DuctShape, DuctSizes> pair
in settings )” into python?
Cheers
for sizes in GetDuctSizeSettings:
	for s in sizes.Value:
    #Continue your code here to extract....
And also refer to .NET Dictionary class:
Thank-you @Kulkul I’ll try your suggestion.
Cheers
Hi @Kulkul thanks for your link, I can now get the values, but this type of dictionary it’s actually over my head :slight_smile:
Have a good day.
Cheers
Here is an alternative with nested Python dictionaries to find properties for one size
import System
import re
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
getDuctSizeSettings = DuctSizeSettings.GetDuctSizeSettings(doc)
def convertDiamValue(mepSize):
	value = mepSize.NominalDiameter
	if sdkNumber < 2021:
		value = UnitFormatUtils.Format(doc.GetUnits(), UnitType.UT_HVAC_DuctSize, value, False, True)
		return value
		value = UnitFormatUtils.Format(doc.GetUnits(), SpecTypeId.DuctSize , value, True)
		return value
typeStr = IN[0]
sizeStr = IN[1]
mepSizeDict = {}
iterator =  getDuctSizeSettings.GetDuctSizeSettingIterator()
while iterator.MoveNext():
	pairValues = iterator.Current
	keyName = pairValues.Key.ToString()
	values = pairValues.Value
	# get all properties
	firstObjet = list(values)[0]
	getprops = clr.GetClrType(firstObjet.GetType()).GetProperties()
	mepSizeDict[keyName] = {convertDiamValue( x) : {p.Name : p.GetValue(x) for p in getprops if re.search(r'Diameter', p.Name) is None} for x in values}
OUT = mepSizeDict.get(typeStr).get(sizeStr)
Hi @c.poupin great! Thank you for your reply, I’ll try to learn and modify your python code to find the way to create a dictionary like @Kulkul.
Have a good day
Cheers
Hi Paris, output looks great. could you please provide the dynamo script?
