I want to create nested groups. In this example i want to create 3 groups in order based on a list.
Starting with group #1 → #2 → group #3 should contain a familyinstance + group #1 (called “fotöljer”)
But this does not seem to work. Group #3 does not contain group #1 when done. Even though the output from my node is containing the last collection with the correct ID:s.
Do i need to regenerate in between creating groups? Or restart transactions somehow? I Think i am already doing that? ![]()
Any help would be appreciated. I have tried as a test to create a group containing a familyinstane+a group and it works fine if the group already exist. But not if the group is created in the same node.
#Standard boilerplate code
import sys
#sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import ElementId
def flatten(l):
return [item for sublist in l for item in sublist]
def find_group(elem_name):
group_elem = FilteredElementCollector(doc).OfClass(Group).WhereElementIsNotElementType().ToElements()
elems_inf = []
for e in group_elem:
if (e.Name == elem_name):
elems_inf.append(e)
return elems_inf[0]
gMembers = UnwrapElement(IN[0])
gNames = UnwrapElement(IN[1])
gTypes = UnwrapElement(IN[2])
myCollection = List[ElementId]()
for index, name in enumerate(gMembers):
temp = gMembers[index]
type = gTypes[index]
#doc.Regenerate()
myCollection.Clear()
for i,j in zip(temp,type):
if (j == "System.String"):
elem = find_group(i)
myCollection.Add(elem.Id)
myCollection.Add(i.Id)
new_group = doc.Create.NewGroup(myCollection)
new_group.GroupType.Name = gNames[index]
OUT = myCollection
