How to find the nesting level of Revit families?
Hi, I’d like to know if there’s a way to obtain the nesting level of a group of families loaded in a .rvt file using Dynamo. Many thanks in advance!
So you want to know how many families are nested within a family?
Hi SeanP, exactly!
I think this should work for you.
#Sean Page, 2021
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
#TransactionManager.Instance.EnsureInTransaction(doc)
TransactionManager.Instance.ForceCloseTransaction()
famDoc = doc.EditFamily(element)
fams = FilteredElementCollector(famDoc).OfClass(Family).ToElements()
#TransactionManager.Instance.TransactionTaskDone()
OUT = fams
Many thanks!! It worked as a charm. I’d like to know, precisely, how to make it work with multiple families at the same time. Is it possibile to do so?
You could either save the Python script @SeanP provided you into a Custom Node (.dyf), or modify the Python to handle lists; if this is your first experience with utilizing a Python script within Dynamo I’d recommend giving the latter a try. This post gives a good breakdown of modifying Python scripts in Dynamo to handle lists and the section on Python scripts in Dynamo in the Dynamo primer has an example as well!
It would look something like this in Python, or you could wrap it into a custom node as @awilliams noted.
#Sean Page, 2021
Families = UnwrapElement(IN[0])
Nested = []
FamilyDocs = []
for Fam in Families:
    tempNest = []
    famDoc = doc.EditFamily(Fam)
    for f in FilteredElementCollector(famDoc).OfClass(Family).ToElements():
        tempNest.append(f)
    Nested.append(tempNest)
    #So you can close the Family Documents
    FamilyDocs.append(famDoc)
OUT = FamilyDocs,Nested
Many thanks! That’s exactly what I was looking for. Many thanks! :slight_smile:
