Recovering nodes
I did this script a few years ago and loaded a few scripts from the Dynamo library to make it work. Now when I open the code on a new laptop I cannot remember what blocks I had used from the library to download them again and make it work. Is there any way I am able to fix my code to run again, please?
Image below if anyone could help me pleaseeee. Much appreciated.
Based on the image you’ll need to install the Datashapes package that is compatible with your Dynamo version. If you’re in a current (Dynamo 3.0+) build try the latest build on package manager; if you’re in older you’ll need to go back a few builds to find the right one for your system/project.
Hi Jacob, Thanks a million for the quick response. Brillhant, it worked!! I have only one more block to add. Do you please know which package I need to add for this one?
Likely a package with excel in the name, but I have no idea which. Best to switch to the out of the box OpenXML excel import node, or the out of the box Read Excel node.
