Rebar.SetLayoutAsMaximumSpacing
Hi All,
Can anyone tell me why the Rebar.SetlayoutAsMaximum.Spacing isn’t working for me?
creating one works just fine. output in the set max spacing is the same as rebar by curve.
Thanks in advance
sadly. i just saw in another post that the package is outdated :frowning:
is there another solution apart from creating my own phyton script using api? im not exeprienced enough for this stuff.
Hi there. I write this down here for anyone coming later.
The “Rebar” package from BIM4 and “Dynamo for Rebar” (Publisher: CoreStudio) are both out of date on Revit 2024 (and maybe 2025).
You should try using the package (GH for Rebar version corresponding to the one you’re using).
tRw from Sterling Engineers
