Rebar Creation
Hey everyone,
I am trying to make rebar using Rebar.bycurve and i facing the below issue. it was working perfectly in Revit 2017 but not anymore in 2019. your help is appreciated also find the revit model and the script below.
for inputs: edge of the element and the rebar bar
04a Beam Transversal Rebar Distribution.dyn (60.1 KB)
for the model:
https://we.tl/lxNyuHltEj
Thank you
anyone can help ?
Will keep the post open until anybody can answer
Thank you
Problem solved, for anybody interested i will share with him the script
Hello, man. Can you share your solution to the problem?
can you use diroots package " https://diroots.com/dynamo-package-by-diroots/ "
good luck :slight_smile:
