I have never got this node to work. How do l?
Hi guys!
I am pretty new to dynamo, but i think i am close to end this script
i used the to make the detail line with the rebar shape.
after this, I extracted tha A,B,C,D,E,F,G,H parameters and made them strings.
i got centerline points of the initial curve, and obtained some vectors out of them, so the text will rotate.
with all of this (text, location, rotation angle) i used the textnote.bylocation node. Now the problem comes.
I tried all the lacing options, and only 2 results came up.
- one with only the first parameter value in all the point locations.
- one with all the parameters values in all the point locations
i can’t upload anything because i am new to this forum, but i cand send my graph on email.
Thank you very much!
@daniel.gheorghe1
As a new member you can send one image in a post, so you can show the graph here
5 posts were split to a new topic: Rebar to Detail Curve
from Which package the node
curve.deconstructpolycurve
Hey,
Do you mind sharing the code of how you extracted the parameters and added the text?
I am just trying to create a similar code and only got to extracting the centerline of the the rebar shape…
(I am an amateur )
