Please help me one more time?
What could be wrong?
I’m trying to create a routine that after a finished project I can select a wall, change its height, transforming it into a sill and later create the railing. But after many attempts to do this in a single routine, it is giving this error.
Hi its that node from wombat, you could try replace that node so it only have one output, but will probably come again after save…you could try ootb element classes “railingtype”, instead
The problem was exactly in the wombat node, which each use it modified the entry and caused the error. I made the change as suggested and it worked. Thanks a lot again!
