Question: Grid to Geometry or curves
Hi, I am trying to place columns at grid intersections. For that I need to convert Revit grids into geometry, Do you know why the Element.Geometry or Element.Curve nodes giving Empty lists?
A line is already a type of geometry, so you can move on to finding the intersection points.
Use Curve.IntersectAll by Bimorph
edit: I get that your question was to get the geometry. But i read first that you need to put an element on the grid intersection and you need to a point for placement, so I thought just get the intersection directly
Thank you! Something to learn every day :grinning:
Thank you, It works as well
