I’m learning Python for Dynamo.  Lynda.com has a good course.
The Python below returns a list of plumbing familytypes.
I know it is easy using a Dynamo node to get the parent family.
Is there a way to do this with python?
#Import Revit Nodes
Import RevitAPI
clr.AddReference(“RevitAPI”)
Import DocumentManager and TransactionManager
#Filtered Element Collector
collector = FilteredElementCollector(doc)
#Quick Filter
filter = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PlumbingFixtures).FamilyToElements()
OUT = filter
              If I’m not mistaken then your code will return all the family instances in the model instead of the family types.
In that case getting the FamilyType and then the Family from a FamilyInstance (from the top of my head) would be something like this:
FamType = instance.FamilySymbol
Family = FamType.Family
Revitapidocs.com is a great site for looking up above information.
              Just like @T_Pover said, you’re currently getting family instances. You can filter for family types though, then convert those to families.
clr.AddReference('RevitAPI')
dataEnteringNode = IN
collector.OfCategory(BuiltInCategory.OST_PlumbingFixtures)
collector.OfClass(FamilySymbol)
types = collector.ToElements()
families = set()
for type in types:
	families.add(type.Family)
families = list(families)
OUT = families
              Thank you Nick
This is creating a list of Families.
I’ve looked at the set() method.  I think this should be creating a unique list.  The output contains a list that is not unique, it includes the family for each type.
              Can you show me what your code looks like?
              I think the set() method does not do a true “Equals” comparison and I think that although the Element IDs of the famililes are the same in memory they are not treated as the same objects. So a way to fix this is to compare the IDs instead and feed those into the set() method.
I tried to make it clear in this .dyn: Collect families of category.dyn (6.2 KB)
              Sorry I didn’t catch that. It just happened to work on my small test file.
Comparing element Ids seems like the way to go @T_Pover.
