I have the Civil 3D Toolkit package installed, and I cannot seem to find anything that will give me the bearing (direction) of an alignment drawn? I’m trying to pull certain information from alignment data in order to create a table of specific items. I see a bunch of nodes to create lines by direction, but nothing that allows me to query unless I’m just not looking in the right place. Any suggestions?
Hi @SMorykin,
To my knowledge, a node with that functionality doesn’t exist yet. Here’s couple options for you:
You could use AlignmentExtensions.GetGeometry to get the Dynamo geometry for the alignment, and then do a little gymnastics to measure the angle between the elements and the Y axis (or north). However, that doesn’t really work for getting the bearing for a non-tangent entity like an arc or spiral.
Here’s some quick Python code to get the northing, easting, and bearing of any point along the alignment given station and offset.
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from System.Collections.Generic import Dictionary
civdoc = CivilApplication.ActiveDocument
def get_alignment_info(alignment, station, offset):
global adoc
global civdoc
keys = ["Easting", "Northing", "Bearing"]
with adoc.LockDocument():
with adoc.Database as db:
oid = alignment.InternalObjectId
obj = t.GetObject(oid, OpenMode.ForRead)
vals = obj.PointLocation(station, offset, 0.001, 0, 0, 0)
d = {k:v for k,v in zip(keys,vals)}
dict = Dictionary[str,object](d)
t.Commit()
return dict
OUT = get_alignment_info(IN[0],IN[1],IN[2])
Thanks for quick reply. I figured some gymnastics was involved but was having problems with the Line.Direction node and it’s still giving me an error (see below). I did download todays version of the Toolkit, I was hoping additional nodes for the Direction were available. Seems like everything else about an alignment and sub-entities are, thought maybe I was just missing something since there is SO much in that toolkit.
It’s giving the warning because Line.Direction doesn’t work with arcs. You’d need to instead use Curve.TangentAtParameter to get the tangent vector at the desired location.
Brilliant! Thank you!
LOL! You rock, Paolo!
