Query all Project Units
Hello all,
I am attempting to query all of the display units in this Revit file (Length = Feet and Fractional inches, Area = Sq. Ft.). I’ve found a node from GeniusLoci that outputs all of the Unit Types and a python script to get the display units, but for one unit type. The issue I assume I’m running into is a conversion error. Here is a screengrab of my graph and my python script.
Cheers,
doc =  DocumentManager.Instance.CurrentDBDocument
app = DocumentManager.Instance.CurrentUIApplication.Application
clr.AddReference("RevitAPI")
import System
unT = UnwrapElement(IN[0])
result = []
# Place your code below this line
for i in unT:
	cool = Document.GetUnits(doc).GetFormatOptions(UnitType.i).DisplayUnits
	result.append(cool)
OUT = result
Hi @patrick_podeyn,
I think the node you are looking for already exists in the latest versions of the Genius Loci package. :grinning:
You can modify your script like this :
clr.AddReference('RevitAPI')
result = []
for i in unT:
	cool = Document.GetUnits(doc).GetFormatOptions(i).DisplayUnits
	result.append(cool)
OUT = result
Project units2
Thanks! Yeah, I wanted to get this to work in Python purely for learning. It’s nice to know I wasn’t off by much. So, how come I don’t need to put (UnitType.i) and what does the error ‘type’ object has no attribute ‘i’ mean?
Thanks!
