Hi guys,
When i use select model element a detail line —> Script run good.
But when i use script to create detail line —> Script warning in Python Node.
What can i edit this warning ?
Warning and Python Code
Many thank
Hi @mr.engineer.aec,
With the DetailCurve.ByCurve node, you obtain a list of one element.
Your script can’t iterate on a list of lines.
You can use the FirstItem node after the DetailCurve.ByCurve node or modify the script.
clr.AddReference('RevitAPI')
lines = UnwrapElement(IN[0])
if not hasattr(lines, '__iter__'):
lines = [lines]
elements= UnwrapElement(IN[1])
if not hasattr(elements, '__iter__'):
elements = [elements]
elementsRef = ReferenceArray()
for element in elements:
elementsRef.Append(Reference(element))
for line in lines:
dim = doc.Create.NewDimension(doc.ActiveView, line.GeometryCurve, elementsRef).ToDSType(True)
OUT=dim
There is a package with a dozen of nodes to dimension. It will be much easier.
Thank for your help.
I used first item node and script is ran.
I will test your idea package “Genius Loci”
Thank you so much.
Hi @Alban_de_Chasteigner
I can’t search “Dimension By References” node in Genius Loci Packages. in 2018.9.5 Version
How can i search ?
Dynamo 1.3.3
Package Genius Loci 2018.9.5
Please update to the latest version of the package (2019.3.11).
It’s compatible with Dynamo 1.3 if it’s your concern.
