Basicly I have a bunch of groups which might have curtain walls as well as other elements. I want to have a list not with ALL the elements in a group but a list with just curtain walls in that group.
clr.AddReference('RevitAPI')
groups = UnwrapElement(IN[0])
elementlist = list()
test = list()
for item in groups:
try:
memberlist = list()
for member in item.GetMemberIds():
memberlist.append(item.Document.GetElement(member))
if member.GetType().ToString() == "Autodesk.Revit.DB.WallType":
test.append(member.GetType().ToString())
test.append(member.Kind)
elementlist.append(memberlist)
except:
elementlist.append(list())
OUT = elementlist,test
elementlist works fine.
test not …
test is created to see what the result is … if that is like ‘Curtain Wall’ then I want a add a ‘true’ value…
But now the return is ElementId. … I thought wall within a group would return WallType … ?
