Python Template - Dynamo Core 2.3
Hi everyone,
Does someone know how to define the python template for the Dynamo Core 2.3?
Following the guide below doesn’t work. At the path %appdata%\Dynamo\Dynamo Core\{version}\ I am able to see only folders for version up to 2.2.
https://primer.dynamobim.org/10_Custom-Nodes/10-6_Python-Templates.html
The Dynamo core 2.3 is installed because of the Revit 2020.2 version so can make sense to have a different path for it.
Thanks for your help,
Best,
Giuseppe
Hi @Giuseppe_Dotto
Dynamo Core is the folder for the standalone version of Dynamo, also called Sandbox. The version of Dynamo that comes with Revit should create a Dynamo Revit folder, also inside %appdata%\Dynamo. Could you check if that folder is present?
Best,
Martin
Hi @martin.misol,
Yes, this folder is on my system and, following the same steps listed in the manual, it works perfectly.
Thank you very much,
Best,
Giuseppe
