Python script to list label style names
Hi … Please do not refer this post to a package.
How do I get the name property of label styles in a python script, referencing .Net?
The following script results in error OnExit …
Thx for your patience, Kevin.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
cdoc = CivilApplication.ActiveDocument
o = []
with adoc.LockDocument():
    with adoc.Database as db:
            for id in cdoc.Styles.LabelStyles.GeneralLineLabelStyles:
                s = t.GetObject(id, OpenMode.ForRead)
                o.append(s.Name)
            t.Commit()
OUT = o
hi,
here some workarounds with PythonNet 2.5.x
if you can, use IronPython3 directly (via package Manager), ipy3 solved this issue that ipy2 and PythonNet 2.5.x can’t
import sys
o = []
                nameA = s.GetType().BaseType.BaseType.GetProperty('Name').GetValue(s)
                # or
                nameB = s.get_Name()
                # or
                nameC = clr.GetClrType(s.GetType()).GetMethod('get_Name').Invoke(s, None)
                # append result
                o.append([nameA, nameB, nameC])
            t.Commit()
OUT = o
TNANK YOU! That’s really good learning you provided … You’re a Star! Have a great day.
