Hi everyone,
Could someone help me to understand why I’m having this output while trying to simply retrieve the start point of the curve?
Thx
Hi everyone,
Thx
change this:
for curve in curvelist:
templst.append(Curve.StartPoint)
to this:
templst.append(curve.StartPoint)
The way you currently have it, you are trying to get the StartPoint property of the Curve class (from the ProtoGeometry library) rather than that of an instance of a Curve.
Thanks for explanation, @cgartland. This was an easy fix, I guess.
Since everything is case sensitive, I need to pay more attention next time.
BTW, how to retrieve X, Y or Z coord in this case? Do I need to do one more loop? Thx
Assign your start point to a variable and then access its X, Y, and Z properties separately:
start_point = curve.StartPoint
x = start_point.X
y = start_point.Y
z = start_point.Z
Works fine, but the output is only 1 x value, not the values of the entire list. Where is the trick?
curves = IN[0]
# Place your code below this line
output = []
for curvelist in curves:
templst = []
x = start_point.X
y = start_point.Y
z = start_point.Z
templst.append(x)
output.append(templst)
OUT = templst
Stupid mistake.
Anyways, you saved me some time. Cheers!
No problem. Just a heads up–you will need to indent your output list as well, otherwise it will only contain the last templst
