Hi all,
As autodesk has stopped supporting dynamo studio, i have to tranfser my scripts to dynamo inside Robot Structural Analysis 2022.
The base part of my script is working. but i have a list that the script reads wrong.
this is the list as input.
this is the first edit i do. 'take a string from the list at index 0
then in row 272 with dynamo studio 2017 the values where set to the whole list. but now it only works on 1.
This should be the result.
and this is what i get now.
I guess it’s probably some easy steps to take but for me it quite annoying at the moment.
Hope someone of you can explain me why this is happening?
@jacob.small @Jonathan.Olesen
Thanks in advance.
Gr Edward
Can you show the entire loop which contains line 242? Pasting the code as pre formatted text would be best.
@jacob.small
this is the part of the script where i use the function string.
import math
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReferenceToFileAndPath(user +r"\Dynamo\Dynamo Core\1.3\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
from RobotOM import *
from System import Object
Stapinstelling = IN[16]
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
ProjectPrefs = project.Preferences
bars = structure.Bars
nodes = structure.Nodes
j=0
while j<=(profielen-1):
k=0
while Totaal_Unity_UenSLS>=1.0 or RotatieOnder_max_ULS>=anglelimit:
application.Interactive = False
stap = Stapinstelling
loadnodes = str(stap[0])
for h in range(len(Load_INST)):
cas = structure.Cases.Get(Load_INST[h][0])
simplecase = IRobotSimpleCase
simplecase = cas
rec = IRobotLoadRecord
IRobotLoadRecordMngr = simplecase.Records
count = IRobotLoadRecordMngr.Count
for i in range(count+1)[::-1]:
rec = simplecase.Records.Delete(i)
Uniform = []
Uniform.append(simplecase.Records.New(Load_INST[h][1]))
LoadRecord = simplecase.Records.Get(Uniform[0])
LoadRecord.SetValue(0,Load_INST[h][2])
LoadRecord.SetValue(1,Load_INST[h][3])
LoadRecord.SetValue(2,Load_INST[h][4])
LoadRecord.SetValue(3,Load_INST[h][5])
LoadRecord.SetValue(4,Load_INST[h][6])
LoadRecord.SetValue(5,Load_INST[h][7])
LoadRecord.Objects.FromText(loadnodes)
thanks in advance
