Hi everyone,
I am trying to output values from a list based on the length of sub-lists through Python. I am a Python beginner and I am struggling with what I want to accomplish.
The output I want to achieve is inside the red rectangle but I am getting something different:
My Python code:
# Enable Python support and load DesignScript library
#clr.AddReference('ProtoGeometry')
#from Autodesk.DesignScript.Geometry import *
# Import RevitAPI
clr.AddReference("RevitAPI")
# Import RevitServices
dataEnteringNode = IN
goals = IN[0]
pattern = IN[1]
in_range = []
out_range = []
length_values = 0
index = 0
# Place your code below this line
# Loop through the sublists
for sublist in pattern:
length_sublist = len(sublist)
# Check how many items the sub-list has
for goal in range(length_sublist):
length_goals = len(goals)
# check if the sublist length is bigger then the list I want
# To show and output "out of range"
if length_sublist > length_goals:
out_range.append("item out of range")
index = length_goals
# Append the goals items into a new list
in_range.append(goals[goal])
# Put everything together
in_range.insert(index, out_range)
OUT = in_range
I was able to mimic the desired output with Python alone (not in Dynamo environment) though by making a dictionary and looping through the values of that dictionary. I am having troubles applying a similar approach when I use Python within Dynamo.
I am not asking for direct code correction but rather for pointing the right way to achieve what I want based on the given inputs.
Any help is appreciated
test_2.dyn (17.7 KB)
