hi all,
can someone help me out here? I’ve no clue what i’m doing wrong.
the output of math.atan (1) = 0.78, while it should be 45.
hi all,
See you expecting radians because I think that is what you get. 45 sounds like degrees
ah stupit, you’re right. Do i’ve to convert it myself or is there a simple method for?
You could use:
math.degrees(x)
Convert angle x from radians to degrees.
that helps, thanks!
For other material on Python math this is quite useful
https://docs.python.org/2/library/math.html
ah this is perfect! thanks
