Parameters Script Issue
Hello Everyone,
I am running into an error when trying to incorporate multiple parameters in multiple groups into a family in one command. Not sure what the issue is exactly… Any ideas?
code largely inspired by Dimitar Venkov
clr.AddReference(‘RevitAPI’)
parameters = IN[0]
paramgroups = IN[1]
inst_or_typ = IN[2]
families = UnwrapElement(IN[3])
class FamOpt1(IFamilyLoadOptions):
def init(self): pass
def OnFamilyFound(self,familyInUse, overwriteParameterValues): return True
def OnSharedFamilyFound(self,familyInUse, source, overwriteParameterValues): return True
trans1 = TransactionManager.Instance
trans1.ForceCloseTransaction()
result =
for f1 in families:
famdoc = doc.EditFamily(f1)
trans1.EnsureInTransaction(famdoc)
for p in parameters:
    famdoc.FamilyManager.AddParameter(p, paramgroups, inst_or_typ)
famdoc.LoadFamily(doc, FamOpt1())
result.append(True)
OUT = ‘Successfully added %d shared parameters to %d families’ %(len(parameters),len(result))
Your variable “families” consists of a single family. So, attempting to loop over a single family (not a list of families) is not valid. If you are only planning on editing a single family at a time, you can remove your outermost loop:
family = UnwrapElement(IN[3])
famdoc = doc.EditFamily(family)
# etc. etc.
Hey @cgartland,
Thank you so much and that definitely helps so much. However, I was wondering what am I doing wrong?
parameters = IN[0]
paramgroups = IN[1]
inst_or_typ = IN[2]
Blockquote
See this post for additional information. Also, be sure to paste your code as preformatted text instead of a blockquote.
I have also found issues using the TransactionManager with documents other than the current DBDocument. Instead, try creating a transaction manually:
t = Transaction(famdoc, 'Describe your transaction')
t.Start()
# Do stuff here
t.Commit()
@cgartland, I completely understand what you mean. Thanks for helping with that formatting. I just want to figure this out as this is the last part of a very complex script.
@Dimitar_Venkov, I know you made this script a while back but am currently trying to add the parameters to just 1 family rather than the original (multiple families). Any ideas?
clr.AddReference('RevitAPI')
parameters = IN[0]
paramgroups = IN[1]
inst_or_typ = IN[2]
# class for overwriting loaded families in the project
    def __init__(self): pass
#just to make sure everything is closed down
# Dynamo's transaction handling is pretty poor for
# multiple documents, so we'll need to force close
# every single transaction we open
result = []
    result.append(True)
OUT = 'Successfully added %d shared parameters to %d families' %(len(parameters),len(result))
What’s the error you got? The indentation looks a bit off but that might be because you pasted the code in the forum.
Hey Dimitar,
I got the following error:
I am basically trying to have multiple Parameter groups with multiple parameters go to a single family and/or multiple families. Any ideas?
Sincerely,
Kevin
Right now you’re feeding in a list of Parameter groups but the code expects a single one. You’ll need to iterate over each of the PGs and run the add command. Something along the lines of:
for pg in parameterGroups:
        famdoc.FamilyManager.AddParameter(p, pg, inst_or_typ)
famdoc.Close(Fasle)
result.append(True)
Hey Dimitar,
I tried making the modifications and adjustments but seems to have thrown a new error? Not entirely sure what is going on that I am potentially missing?
Thanks again bud,
Kevin
what did the inputs look like?
Hey Dimitar!
Please see both the code and inputs. I hope the screenshot shows all the inputs needed. I just do not know what is causing the issue?
parameters = IN[0]
paramgroup = IN[1]
inst_or_typ = IN[2]
trans1.ForceCloseTransaction() #just to make sure everything is closed down
result = []
for f1 in families:
for pg in paramgroup:
famdoc.Close(false)
result.append(true)
Any ideas and Thank you again!
Kevin
P.S. Starting this Friday, I am going to start taking C# classes and train myself in the ways of API’s to get more into Revit API :slight_smile:
Hey @Dimitar_Venkov, just wanted to follow up on what I am doing wrong? LOL
Thank you for your help bud!
Everything looks right. Look at the error, it’s different. It’s telling you there’s already a parameter called “Structural Usage”. To add some robustness, you could add a try/catch block:
        try:
        except:
            pass
Hey Dimitar,
Thank you so much bud! This did it. The reason why I wanted to make this script is when we have custom Shared Parameters and get a clients file… I do not have to manually (or my team) need to add in each Shared parameter 1 by 1… Such a pain! LOL. Thank you so much and hope you had a great weekend!
