Python for Loop - Hide Grid Bubbles
Also working in my other projects, i think i just had wrong bool settings before.
Thanks a lot Nick for guiding me through :smiley:
Here is my final graph and python code, i changed the variables in the code to make more sense.
For my purposes i need 3 different bools for the grids:
  • Is x vector positive
  • Is y vector positive
  • Is vertical
This graph will now show the left bubbles and hide the right bubbles. If the grids are vertical then only the upper bubbles are active.
from RevitServices.Persistence import *
clr.AddReference("RevitAPI")
app = uiapp.Application
if isinstance(IN[1], list):
	gridList = UnwrapElement(IN[0])
	viewList = UnwrapElement(IN[1])
	xVectorPositiveList = UnwrapElement(IN[2])
	verticalList = UnwrapElement(IN[3])
	yVectorPositiveList = UnwrapElement(IN[4])
	gridList = [UnwrapElement(IN[0])]
	viewList = [UnwrapElement(IN[1])]
	xVectorPositiveList = [UnwrapElement(IN[2])]
	verticalList = [UnwrapElement(IN[3])]
	yVectorPositiveList = [UnwrapElement(IN[4])]
for grids, xVectorPositives, verticals, yVectorPositives, view in zip(gridList, xVectorPositiveList, verticalList, yVectorPositiveList, viewList):
	for grid, xVectorPositive, vertical, yVectorPositive in zip(grids, xVectorPositives, verticals, yVectorPositives):
		if xVectorPositive: #boolean check
			grid.ShowBubbleInView(DatumEnds.End0,view)
			grid.HideBubbleInView(DatumEnds.End1,view)
		elif not xVectorPositive and not vertical:
			grid.ShowBubbleInView(DatumEnds.End1,view)
			grid.HideBubbleInView(DatumEnds.End0,view)
		elif not xVectorPositive and vertical and yVectorPositive:
doc.Regenerate()
OUT = viewList
