so you have said:
for views in v:
But then you have said:
g.ShowBubbleInView(DatumEnds.End1,v)
instead of:
g.ShowBubbleInView(DatumEnds.End1,views)
The warning gives a clue ‘List object’ has no attribute… Instead of ‘Grid object’ for example… I also try to comment my way through the code, explaining it to myself helps me better understand what is going on. Also trying to keep everything very obvious helps me
viewList = UnwrapElement(IN[3]) #unwrap everything in the list
TransactionManager.Instance.EnsureInTransaction(doc) #start transaction
for view in viewList: #get each view in the viewList
for g, bx, by in zip(g, bx, by): #run through everything in the sub lists, keep them the same length
if bx and by: #boolean check
g.ShowBubbleInView(DatumEnds.End1,view) #in each view show if the end value is true
Hope that helps,
Mark
