i was trying to get the element ID of the selected elements. but when write the code below code is not working. which library I supposed to import to work it properly.
uidoc = commandData.Application.ActiveUIDocument
Will get you the active document. You’ll need to supply more details about what you’re trying to achieve for the rest
thank you, is there any document for the library
The UIDocument has a Selection property. Referencing the Selection class, you can use the GetElementIds method to get the element ids of the current selection.
I created below code to pick the object from screen. but it is not working.
from RevitServices.Persistence import *
app = uiapp.Application
clr.AddReference(‘RevitNodes’)
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB import APIObject
from Autodesk.Revit.DB.Mechanical import *
clr.AddReference(“RevitAPIUI”)
ref = Autodesk.Revit.DB.Reference
sel = uidoc.Selection
po = sel.PickObject
po1 = po.Targets
#selid = sel.GetElementIds().Count
selob = sel.PickObject(ObjectType.Element)
OUT = selob
Once you have the uidoc, you can get the ids of the elements as @cgartland says, and from there the elements themselves by querying the doc:
ids = uidoc.Selection.GetElementIds()
elems = []
for id in ids:
try:
elems.append(doc.GetElement(id))
except:
elems.append('Element retrieval failed')
OUT = elems
revitapidocs: Selection.GetElementIds
revitapidocs: Document.GetElement
