Hi guys, first of all, thank you for everyone’s contribution to the forum. I’ve been able to learn a lot of Dynamo in the past year or so mainly by looking for solutions in the already existing posts. with that being said, I have a Working Script I’m trying to use along with the Data-Shapes node however once I started implementing the Data Shape UI the Python portion of the workflow doesn’t seem to work properly. Here’s the graph:
Python
from RevitServices.Persistence import *
clr.AddReference(“RevitAPI”)
app = uiapp.Application
g = UnwrapElement(IN[0])
b = UnwrapElement(IN[1])
v = UnwrapElement(IN[2])
for g, b in zip(g, b):
if b:
g.ShowBubbleInView(DatumEnds.End1,v)
g.HideBubbleInView(DatumEnds.End0,v)
g.ShowBubbleInView(DatumEnds.End0,v)
g.HideBubbleInView(DatumEnds.End1,v)
doc.Regenerate()
OUT = g
If I bypass the UI block and connect one of the quadrants directly to the Python node the action works flawlessly:
Any idea how can I fix either the workflow or the Python Node so I can use the Data-Shape UI?
Thanks in advance!
