# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit import Creation
app = uiapp.Application
# Start Transaction
rvtComId = RevitCommandId.LookupPostableCommandId(PostableCommand.PurgeUnused)
post = uiapp.CanPostCommand(rvtComId)
# End Transaction
`OUT=post`
I tried using postable command but it would’nt work,but it would not give a error it would just return true
As I’m aware Purge is not accessable in the API
Would i be able to at least bring up the purge Window and manually select purge all?
Wouldn’t it be easier just to bind a keyshortcut to Purge then?
This is part of a bigger workflow where i delete sheets,view,schedules…and unpinned elements so purging would be the final step before i save the files
Ive done everything else in Dynamo using python …so i wanted to do this too
If theres no other way then il do it manually:expressionless:
I might eat my words.
Someone found a solution, read here: https://gitlab.com/MattTaylor/RevitPurgeUnused.
It is for Revit 2017+.
Try translate it to python :-).
And as you were doing in the start, they also use the Postable Command
i saw this in the version history of the Dynamo Automation github site by @Andreas_Dieckmann
It also says it has not been tested with 2.x
1.3.3
New nodes:
- Journal.PurgeModel
- Journal.PurgeModels
- Journal.RevitStartupArguments
- Process.KillCurrentProcess
Thanks @Marcel_Rijsmus - interesting! Any idea when @Andreas_Dieckmann will test it for 2.x?
Hi @ashwinash112,
The Postable command works like this :
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI import RevitCommandId
from Autodesk.Revit.UI import UIApplication
from Autodesk.Revit.UI import ExternalCommandData
RunIt = IN[0]
if RunIt == True:
CmndID = RevitCommandId.LookupCommandId('ID_PURGE_UNUSED')
CmId = CmndID.Id
uiapp.PostCommand(CmndID)
errorReport = 'Success'
errorReport = 'Set IN[0] to true'
#Assign your output to the OUT variable
OUT = errorReport
very useful. Thanks a lot!
This is great - but purging just once doesn’t do the job properly - does anyone have an idea how to get this command to execute 3x within a script. Even if i put the python node in 3 times in the script it only executes once. Has this been solved elsewhere?
Thanks Alban,
Very interesting
Do all of the (postable) command IDs have the same string syntax? I couldn’t see a list anywhere in the revit api docs, just a reference to the journal file, which is a bit of a random process to find them
Cheers,
Mark
Awesome thanks, 1287 commands will keep me going a while!
Awesome nodes, Luke, thank you very much.
Guys, you can grab his dyn files on GuitHub.
