Hi there,
regarding parameters in Advance Steel, apparently there is difference between “Attributes” and “Object Properties”.
You can get values from both Attributes and Object Properties, but only set it to Attributes.
In order to set values from OP to Attributes, you can turn it into a string, and chop the name of the Property.
But how does it work the other way round?
-Do I have to synthesize the value and the name of the property?
-Is there an example on how to get this node to work?
-Can I acces the code?
Kind Regards,
Willem
Please find a graph and model included…
test 1 plate Property.SetObjectProperty.dwg (44.3 KB)
Write to Object Property.dyn (88.7 KB)
