Property definition (automatic)
Hi, could you please advise me if it is already possible to create a property set definition with a property definition that is of type automatic, such as Volume for 3D solids. I tried creating a property definition volume manually and then copying it to property set definitions, but the property definition value copied in this way was then not showing up in the exported IFC files.
PsetV01
Hi…did you apply or add this property set to elements already drawn in your file?
Hi @alaasaid_10, thank you for respons. I can use Dynamo for property set definition creation also to apply them to 3D Solids (in style manager or to created objects in model space). I only need to create automatic property definitions in property set definitions using Dynamo.
ok, I understood your point, I think you will find your answer in this video Dynamo for Civil 3D - Property Sets samples | Civil 3D 2020 | Autodesk Knowledge Network
you can also check this discussion
Civil3d Property sets with dynamo - #13 by rhodri.lea
Also there is a useful package that can help you in creating property set definitions using Dynamo called “Civil3DToolkit”.
Thank you for mentioning Property set samples. I hope this part of code from @Paolo_Emilio_Serra1 can help me.
                        for jpd in jpsd.Definitions:
                            pd = PropertyDefinition()
                            pd.Automatic = jpd.Automatic
                            pd.DataType = DataType.Parse(DataType, jpd.DataType, True)
                            pd.Description = jpd.Description
                            pd.Name = jpd.Name
                            if not definitions.Contains(pd):
                                definitions.Add(pd)
Hi, I found this Defining a property set definition in .NET - AEC DevBlog
I was not successful with Python. Is here anyone who has code in Python?
