Does somebody have a clear answer that Dynamo returns the arries of properties in which the order does not match from a same material?
I’m actually not sure if it’s Dynamo or Revit
I suggest you post where you are up to and the area of issue while also looking at the following post
You cannot guarantee everything will be the same order everytime you run a script,therefore you have to build in some sort of system to organised things or you implement a checker to get certain areas of interest that match what you are after(eg sheets that are all A1)
Daniel, thank you for your reply!
Yoji
Brendan,
Thank you for your post.
I wanted to get an understanding of this condition such as this result is derived from asynchronous processing result.
But I should post my question on right place as you mentioned.
Thanks.
Yoji
