Hi everyone,
I’m pretty a beginner with Dynamo + Revit. I’m struggling with an issue and cannot get rid of it.
Besicaly i’m using Dynamo to generate Revit elements and then to modify their properties.
When I try to do it with columns i get a “serious error” message from Revit and get no results (no column generated).
I managed to isolate the part of the code that makes Revit crash, here it is.
However, if I freeze the nodes that modify the column, run the script to generate the column and after rerun all unfeezing all the nodes I get the results I want… (column generated in the first run, column modified in the second).
I imagine it’s some sort of issue with the order of execution of the nodes.
The really weird thing:
I have almost the same nodes structure for walls but gess what: no problem at all with walls…
Can you suggest a way to solve this problem?
Thank you very much!
